Connectivity Program
Platform Foundation
Asset Service
MediaCentral | Media Suite API
The MediaCentral | Media Suite API provides a common Avid MediaCentral Platform entry point into Avid back end services, including MediaCentral | Production, MediaCentral | Asset Management and MediaCentral | Newsroom Management. Use the APIs to gain access to the media assets held in the target back ends, using core Avid Platform services exposed in a unified, managed and coherent manner.
Foundation Service
MediaCentral | Service Gateway
The MediaCentral | Service Gateway is the framework for integration of your custom service into the Avid MediaCentral Platform. It was designed from the ground up for a multi-zone environment with deployment across geographically remote machines where multiple service instances are possible. All service discovery and request routing is managed by the Avid Connectivity Service bus, the communication backbone of the Avid Platform.
The same API is used internally by MediaCentral Services.
MediaCentral | UX Toolkit
The MediaCentral | UX Toolkit includes everything you need to integrate external tools and services into MediaCentral | Cloud UX workflows as a UI plug-in. For example, use it to integrate a web-based project management system, or your own custom software offerings. Features static (client-side) UIs for simplified integration of JavaScript libraries, while retaining the ability to match the style of the native MediaCentral | Cloud UX user interface, as desired.
MediaCentral | API Gateway
The MediaCentral | API Gateway is the bridge interface between the bus and the outside. It allows clients to communicate with services on the bus via a REST interface. At the same time MediaCentral | API Gateway is the control instance which makes sure that all requests coming in are coming from an authenticated user and it can take care of load balancing calls when needed.
Coming soon
MediaCentral | Graphics API
The MediaCentral | Graphics API allows for integration of external MOS based graphics systems. It gives you the ability to store MOS data in MediaCentral | Newsroom Management Stories and to render graphics from your graphics system over the player in MediaCentral | Cloud UX.
Coming soon
Client Applications
Essence SDK
AAX
Create high-quality audio effects and virtual instrument plug-ins for real-time and off-line audio processing in Pro Tools, Media Composer, and VENUE systems.
AVX
Create resolution-independent, cross-platform visual effects plug-ins for Avid creative tools.
Avid Media Access (AMA)
Avid Media Access (AMA) is a plug-in architecture that allows users to link to and write back (export) common media formats and popular interchange formats, like MXF OP1a, AS-11, AS-02, MOV, and MP4, that are not supported natively within Avid environments. This architecture eliminates the need to convert to Avid native formats, e.g., from XDCAM EX MP4 into Avid OPAtom carrying XDCAM EX, so that users can link to acquisition formats and associated metadata for immediate viewing and editing. The architecture also allows for write back/export to popular delivery formats. By creating AMA plug-ins, developers can enable rich workflows with custom media file formats and associated metadata within Avid environments.
MediaCentral | Graphics Engine API
The MediaCentral | Graphics Engine API supplies development resources, graphic and code samples for third-party developers to connect to the RenderEngine 7 real-time graphics renderer.
Create your own control interfaces and data handling applications that can then be used to control Avid’s RenderEngine 7 during productions. Minimum requirements for installation: Microsoft .Net 4, Microsoft VC++ redistributables
Recommended components: 4Designer 1.1, RenderEngine 7.0, SharedData 7.0 (or newer)
Transport SDK
EUCON
EUCON is a control surface-to-software application protocol that transcends the bandwidth limitations of the traditional MIDI interface used by many control surfaces. It can support user interfaces with thousands of high-resolution controls, for a user experience that combines the advantages of large physical control surfaces with the flexibility and power of software applications.
Open I/O
Avid Open I/O allows manufacturers to develop their own plug-in for their hardware to function with Media Composer, Symphony and NewsCutter. They can now bring Avid video editing compatibility to their hardware I/O cards and devices.
Scorch iOS SDK
Create iOS apps to display, play back, transpose, change instruments, layouts, etc., for native Sibelius (.sib) and encrypted (.sco) files. In addition, can display PDFs and music XML files.
Coming soon
Distribution Service
Sibelius | Cloud Publishing
Take music scores created in Sibelius, or MusicXML or PDF files, and publish into a web browser consumable format.
Metadata Service
Sibelius ManuScript
Sibelius ManuScript is a simple, human-readable scripting language that helps you automate frequent actions or perform complex musical operations on scores. Script creation is simplified since the scripting language features built-in musical concepts including Score, Staff, Bar, Clef, NoteRest, etc.
Coming soon
media services
Metadata Service
Dialogue Search
The Dialogue Search REST API enables users to integrate the fast and powerful speech search and metadata search and filtering of a Dialogue Search server into any application. Programmatically import media from any number of diverse media stores.
Illuminate
The Illuminate REST API enables users to fully automate the creation of profiles and execution of jobs to validate closed captions, language, and video description. Access detailed job results, automated pass/fail analysis based on user-defined criteria, and retimed captions.
Job Service
MediaCentral | Command API
MediaCentral | Command provides precise automation control over a range of Avid and other popular video and graphics devices. It manages news playout reliably by dynamically linking with newscast rundowns. The MediaCentral | Command API opens the iNEWS MediaCentral | Command platform for video servers and graphics devices, allowing flexible workflow configurations.
MediaCentral | Capture API
The Capture API provides SOAP web services for interacting with MediaCentral | Capture. The API allows software developers to perform numerous operations including adding, removing, or changing scheduled recordings, starting and stopping recordings. Also covers schedule-based operations, including downloading the whole schedule, watching the schedule, and monitoring the schedule for changes.
Asset Service
MediaCentral | HTML5 MOS API
The MediaCentral | HTML5 MOS API allows third party plugins to create and edit MOS plugin data (add MOS XMLs) in MediaCentral | Newsroom Management stories. MOS data is displayed as production queues in a MediaCentral | Newsroom Management story.
Coming soon
MediaCentral | MOS SDK
Coming soon
MediaCentral | Production API
The MediaCentral | Production API provides SOAP web services for interacting with Avid MediaCentral | Production. Among other things, the API allows software developers to access media file location, resolution, approximate file size, metadata, and selected services managed by MediaCentral | Production, and to trigger selected MediaCentral | Production features.
Essence SDK
Avid Media Toolkit (AMT)
Avid Media Toolkit enables the process of creating and reading compliant Avid OP-Atom media files and matching AAF metadata, and exchanging them with an Avid MediaCentral | Production workgroup environment or Avid creative tools like Media Composer. It provides a frame-based API that is often used with a second SDK, for example for reading MXF or QuickTime-based media frames and converting them to Avid OP-Atom. AMT includes codec support for Avid native formats such as JFIF or H.264 proxies. It optionally includes the DNxHD codec for partners that have licensed the DNxHD/DNxHR codec. AMT also supports a pass-through mode for reading and writing OP-Atom packaged XDCAM, XAVC-I, AVC-I and JPEG2K, as well as >HD DNxHRmedia. AMT depends on Interplay | Web MediaCentral | Production API for check-in/out functionality.
Contact Partner Programs for more information.
MediaCentral | Delivery API
MediaCentral | Delivery API enables multi-site workflows by smartly handling transfers of media, sequences, and shot lists between MediaCentral workgroups, using industry-standard FTP. For facilities that use a different transfer protocol infrastructure, the MediaCentral | Delivery API is the mechanism for integrating it into the Avid MediaCentral | Production ecosystem.
Transfer Service
MediaCentral | Archive Production API
The MediaCentral | Archive Production API enables archive vendors to seamlessly integrate their middleware with MediaCentral | Archive Production's archive and restore functionality. Similar to MediaCentral | Transfer DET API, the MediaCentral | Archive Production API provides access to Avid media files already wrapped in MXF but also supports the MediaCentral | Archive Production engine for greatly simplified metadata handling.
MediaCentral | Transfer Auto API
Use the MediaCentral | Transfer Auto API to control MediaCentral | Transfer functionality from your Windows application. Includes the ability to invoke ingest, MediaCentral | Transfer DET API, playback and workgroup-to- workgroup transfers, as well as to pause, cancel, resume, and retry transfers, and monitor transfer status.
MediaCentral | Transfer DET API provides programmatic access to the MediaCentral |Transfer Engine. Use it to integrate your ingest, transcoding, playout and/or archiving device with the MediaCentral workgroup environment, including ISIS storage. MediaCentral | Transfer DET API is when the target file is already an Avid media file wrapped with MXF or OMF metadata.
MediaCentral | Transfer DHM API
MediaCentral | Transfer DHM API is the Data Handling Module SDK for MediaCentral | Transfer, used for developing integrations to Windows-based applications that deliver or consume video frames from or to custom file formats or devices. The MediaCentral | Transfer DHM API lets you create a plug-in compatible with MediaCentral | Transfer to push and pull image frames stored on your custom device to and from an Avid editor or shared-storage device.
storage suite
AirSpeed
AirSpeed API
Integrate control systems using a TCP/IP socket-based protocol to query and control AirSpeed ingest/playout servers. Includes commands for obtaining hardware readiness and configuration information, interacting directly with the AirSpeed database, as well as sophisticated transport control commands. Commands are sent and received using XML (Extensible Markup Language) formatting.
Already an active seller on Marketplace? Access the Marketplace portal here.
